After we had an auto electrician check out the car ( suggested body control module ) I discovered the carpet was soaking wet, removed carpet to find main water leak was entering car through plastic grommet above brake pedal that the main wire loom runs through, have re-sealed this & a small leak through pollen filter but car continued with problem on & off untill ten days ago & so far all has been quiet, any more progress & I'll let you know.Did any of you solve the `dash lights flashing wth engine off` problem??
Please advise how.
I have the same - see my posts under name PVROSE
has anyone actually sorted this, as i have the same problem and no one seems to have posted that anything works?
My 2001 1.6s is doing the same, have sealed leaks, cleaned/ replaced earths
Cant find any evidence of any immediately but did the round with wd40, gave it a run and this was a week ago now. first time this happened i had the battery disconnected for a week when i went back it was fine but has now been gonig 24/7 for 6 days without stopping
also, do you know if the abs sensors should pull out once the bolt is removed
thanks again
