de cat question about engine management light
tomtj09
i have recently fited a de cat pipe on my lcr and my engine light has come on . i have searched it alot and most people say to get the rear lamba sensor maped out but a few are saying about a piece that screws into the exaust and the lamba sensor screws into that .. i think they called it a vwvortex stoper or something , will one of these stop the light coming on , where do i get one or do i have to get it maped out ??
im thinking of putting the cat back on but dont want to cus the de cat makes the car sound much better .:(
any help please ??
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Its called a Wayne angle block, have a search through the threads on here :)
tomtj09
cheers mate . so will this stop the light for good and alot of people are saying it can cause alot of damage just fitting a de cat pipe . will it sort all that out ??
thanks .
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm running that excat block above with no problems at all.
I have a normal Cupra not a R but I can't see it would make any difference?
tomtj09
where can i get one from ?? ive searched on e bay but no luck .....
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
"Wayne Schmidt has developed a fitting to solve the CEL problem. His fitting has been thoroughly tested and is running on hundreds of VWs with a stellar success rate. Pictured below, this fitting installs in place of the second oxygen sensor and relocates the sensor outside the flow of gasses. The sensor is installed at a 90° angle to clear the heatshield and ground. The fitting is CNC machined from 303 and 316 stainless steel, guaranteed to last forever and is a completely reversible modification. Wayne's fittings are available by emailing him directly: [email protected] "
