DaveP said:
Andrew there is a dealer in chippenham, maybe they would be more friendly?
How about posting the codes on here? (not suggesting that I have a clue, but some people do).
Also there is vwvortex which, being american biased, seems to have more home mechanic type people and those codes might have already been discussed.
I've tried the Chippenham dealer Dave, and they have exactly the same policy. Anyway here's the codes -
VAG-COM Version: Release 303.1
Control Module Part Number: 1C0 907 379 E
Component and/or Version: ESP FRONT MK60 0104
Software
Coding: 0019970
Work
Shop Code: WSC 78954
2 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
008 - Implausible Signal - Intermittent
012 - Electrical Fault in Circuit - Intermittent
Control Module Part Number: 06A 906 032 DE
Component and/or Version: 1.8L R4/5VT G 0001
Software
Coding: 11510
Work
Shop Code: WSC 11111
1 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
Control Module Part Number: 1J0 959 799 AH
Component and/or Version: 8P Zentral-SG Komf. 0001
Software
Coding: 04099
Work
Shop Code: WSC 06441
Additional Info: 1J0959802F 8P Tõrsteuerger. FS0002r
Additional Info: 1J0959801G 8P Tõrsteuerger. BF0002B
Additional Info: 1J4959811C 8P Tõrsteuerger. HL0002r
Additional Info: 1J4959812C 8P Tõrsteuerger. HR0002r
1 Faults Found:
00943 - Heated Exterior Mirror: Driver Side (Z4)
35-00 - -
