whats the chance of my leon passing the mot with the decat on. What are you guys doing for your mots
Yes, it'll need mapping out. I know you can get lambda sensor probe extensions to put it further away from the exhaust gases which can help to trick the ECU into thinking its closer to its parameters but it's not guaranteed.Would swapping from cat to decat (or vice versa) cause the eml to stay on?
Tempted to fit dummy cats to mine.
Stage 1 remap 18T bam engine.
Rich
I fitted one of the right angle spacers and it worked a treat. It's actually still on with my sport cat now simply because it wasnt throwing a light up either way. Suppose it would be better to have the sensor in but need to extend the cable.Yes, it'll need mapping out. I know you can get lambda sensor probe extensions to put it further away from the exhaust gases which can help to trick the ECU into thinking its closer to its parameters but it's not guaranteed.
I have one on my decat but as I didn't map the car I have no idea if its needed or not without experimenting first.
Sent from my SM-G986B using Tapatalk
