Kyle Townend
233
Right, after literally minutes of sanding, my aero wiper blade still squeeks on the return journey, and the cap still pops away from the glass causing it to block the jet spray, and its been nothing but trouble since I bought it!
I now think its putting too much pressure on the glass, so I plan to put a washer inbetween the wiper and the glass - however, I CANT GET IT OFF AGAIN! :censored:
Is there a technique for pulling it off, I cant for the life of me remember how it came off last time!
Cheers.
definitive answer, just wait for the facelift to come out, then you can buy that one which you know will fit.
Plus get the front aeros at the same time
Cheers.
You must not of had your weetabix (sp)! Just comes off by pulling it really hard!
You need to take off about 7.5mm to make it fit without touching the window! Only take the material off the bottom edge of the cap!
Hope that helps abit
Ok thanks alot guys, so literally the ONLY way to get it off is to rag the arse out of it?
Im scared of breaking the window :lol:
I saw the facelift ibiza at the dealer today and the back wiper isn't an aerotwin type:( .It's just a normal wiper with some kind of cap over.
