Display - Clock
montana83
52
Hampshire
When i first start my 03 leon every morning it display temperature is there any way to make this default to the clock instead, as i like seeing how late for work i am ;) ;)
jesta1865
land rover saddo :-)
Oct 25, 2002
109
essex
i am under the ipression that it defaults to the temp if its 7c or less so that you know there may be ice out there somewhere.
once its above this it starts on the clock in our 52 cupra.
mrcoyote
See no evil...
Jul 26, 2004
2,624
I'm sure it depends on the mode it was last set to, so if you poke the computer buttons so it's on clock it should default to it, except as above when it's cold.
sjtscott
Now with added Revo! :-)
Apr 15, 2003
505
London UK
Think its around max 5 degrees C or lower it automatically switches bach to temp from whatever you've had it set on.. it displays a little snowflake symbol too when this auto switching is active as its designed as a potential ice warning.
Robdrums
"Bitchtits"
Feb 18, 2006
210
Surrey
Once you're moving, if it detects it's damn cold again (even if you've already told it to shut up, you know there might be ice on the road), it overrides what you want to see and tells you the temperature again. Very annoying, I thought there was something wrong with it when I first had it.
My friend's just bought an Ibiza SX and apparently that beeps at you to warn you of this. At least the Leon is a silent warning I suppose.
Rob
paul h
360
Lincoln
Rob
yes this very annoying it does my head in sometimes :(
matt_s
4 8 15 16 23 42
Dec 23, 2004
657
19
Is there something I'm missing? The only thing of any use on the display is the clock and temp, I sometimes use the distance bit to see how far I've got left on regular journies. I used to use the oil temp on my golf gti but that's not there now anyway.
When it switches to the temp you only need one push of the button and it goes back to what it was on before.
SmartyFR
Leon Fr 1.8 20VT
Dec 6, 2005
68
My dealer said it suppposed to beap when it gets to a certain temperature 5 or below.I have leon fr, is it supposed to beep?:help:
Robdrums
"Bitchtits"
Feb 18, 2006
210
Surrey
Apparently Ibizas beep, but I'm glad the Leon doesn't.
I use the trip computer quite a lot (something to do on motorways :p)
The fuel consumption can be interesting and sort of useful (though I wouldn't look at it if I drove a petrol car)
Rob
