just try to take it to 6500rpm alex, if it wont make it then fair enough but like phil's said, it will provide a much more accurate picture as to whats happening
Yeah i will try, i just hope im not damaging her driving around all the time :(
Hhmm well she passed the MOT today which is good but i asked the local garage to have a look at her after that
They have got new HT Leads on order and a new coilpack as number four is misfiring apparantly although they said i should have them all replaced together but that would be over £100 so they have just ordered one at the moment
He said its completly flat when driven and its quite likely to be the turbo as they sometimes just go but its not smoking or anything so i dont understand? :cry:
andycupra said:
or due to the coil pack the car has backed off...
just change the one coil pack and reset it.
Hhmm yeah could be :think:
I just dont see how it can be something as drastic as the turbo, its not like i even drive my car hard even when im opening it up
If the turbo was gone then no doubt you'd be going through oil like there's no tomorrow, or the car wouldn't be running. Replace the coilpack, reset the ECU then get someone to log the MAF values, Requested and Actual Boost and Load... 002, 115, 114. I'll have a look at it if you're ever in this neck of the woods!
I will check my oil tonight, i had my 60,000 mile Service done about a months ago and they did an oil change then so should be ok
I dont know if the garage will reset the ECU once they have fitted the coilpack? Surely thats standard?
Where abouts are you again?
on kevs behalf, he is in daventry, northants, cannily enough this info can be found on www.revotechnik.com
Cupra 200bhp said:
Thanks for that...! Thats the sort of price i was expecting £350-£400, will get it done when i come back my hols
It may be worth getting a decent Water Pump with the metal impellor? There is some threads on here about them
ht leads eh.... wonder what they gunno do with them?
Well I see no ht leads under a cupra bonnet, since the coilpacks sit on top of the plugs.
