merlin051
Oil Burner!
Aug 22, 2006
186
North East, Darlington
My door release broke, so when i tookt eh door apart i found this:
The other end of the cable connects to the lock unit as below,
Can i just buy the cable and fit it in? or do i need a whole new lock unit for the inside of the door?
And how tricky is this to do if its even possible?
Anyone have any Part no's and prices?
Had a search but it seems that when most peoples handles break tis the actual handle and not the pull wire!
you need to take the few bolts of that hold it on off, you also need to remove the outside door handle. once thats off you can unhook it from the latch bit that moves when you pull the handle. fairly straight forward.
