Dpf delete oil consumption?
WeeG
3,407
Largs , Ayrshire
Just wondering what folks oil consumption is like on there stage 2 fr's. When I first got mine done at 8k it drank a litre in about 1500 miles bit since then (which I put down to engine still bedding in) and frequent oil changes the car consumes next to none over the last 8k car on 17k now, that with 2 oil changes in 8k. What is others consumptions like?
mds1256
Facelift Leon Cupra
Jan 7, 2007
1,012
checked mine the other day actually and has used nothing since DPF delete in April 2010, due a service in April again.
now has 23500 miles on. Had 16000 when got the DPF removed
GrahamFR
Now AMG Powered
Dec 10, 2008
4,235
Barnsley or Burton
well i had mine done, and i had problems with my glow plug control module (seperate related thing), before i knew what was wrong i thought it could be my oil or a whole host of other problems, so i checked it and it was very low. Went to halfords to top up and i noticed that they did oil that should work in conjunction with your DPF, so i bought some other other oil for cars without dpf so i dont know if that was the problem, but i havent checked it since, glad youve reminded me.
Oh yeah, it had 3k on the clock when i had it de-dpf'd and it had 5k on the clock when i checked the oil, and it was down to the bottom marker, and that was after i'd driven to halfords. I better check mine again today!
White_Lady_170
Dirty Derv
Jan 20, 2009
493
N. Ireland
I had mine done at ~30k miles and it was serviced there nearly 1k ago at ~40k miles, fella never mentioned it had used too much/too little so everything is fine i assume :)
10k of trouble free driving (more or less) and hopefully many more to come!
I'd be lying if i said it was enough power for me though, I want more!!! :drive2:
stephenh
73
Nottinghamshire
I find about 1 litre per 10k miles which for a TDI i think is normal. I've done 20k since the de-dpf and all running ok, i do about 600 miles a week and check it prob every week and end up sticking 100ml in or so to keep it topped up.
