But say your car is running DPF delete 210bhp on standard exhaust with DPF internals removed, what's the real world difference going to be like by switching to some form of straight pipe/miltek DPF pipe. Would you really notice that much difference?
I've found out two things over time:
A) the stock diameter is more than sufficient, with no "noticeable" gains, for as much as a CR170 can be pushed at the moment.
B) the flow/back pressure with stock diameter and de-DPF is juuusst right to balance the boost creep which has been part of these things since the pd.
You'd need a pretty good (Revo?) map to make sure that you stay within the MAP limit with mapped boost request + creep.
I know my map isn't that clever. Unfortunately.
Otherwise, yes, 3" tbe and open air intake.
There are reports where the car was grand with normal deDPF, but then "stuttered" or "sudden loss of power" with replacement pipes. Or even with gutting with an aggressive map.
I'd be keen to know from the Revo boys if their map is customised to the levels of creep on each car to really get the best out of them with low-smoke
