Hi guys anyone know a simple fix for driver door lock not unlocking with remote. It's locks fine but I can hear the mechanism struggling.
Leon Cupra R Mk1 2005
make sure you re seal the door inner panel with butyl tape or door will leak, you'll see the old stuff its foam as it crumbles that's if its not already changed , this for example and DONT use silicon sealant it will leak later on
Butyl Sealant Tape uses. Apply this tape directly from the reel onto one surface, and press sufficiently along its whole length to achieve a good initial adhesion. High tack providing excellent adhesion.
