Hi Pinky,
I've been driving my
Leon SC for a couple of weeks now and the wind noise you mentioned has become quite apparent to me with my car. There is a sort of "rushing" sound from my driver side window on accelerating and driving at motorway speeds which is catching my attention and I'm beginning to obsess over it. From your post, do you think I'm able to approach my local Seat dealer with this issue and they can rectify it under warranty?
Or has anyone else any tips on a quick fix for the
problem? Considered the possibility of fitting wind deflectors but I'm unsure if this would solve the issue, or potentially make it worse - I've read reports of increased noise levels when windows are closed with these fitted...
Thanks,
Fraser
Bit of duck tape, that will fix it
Wind deflectors may or not make it better, I imagine it depends on the design of the ones you fit and how they slide in between the window rubber and how the design makes the air flow around the window area etc.
Personally fitting wind deflectors to try to stop the wind noise, is just a slightly neater alternative to fixing it with duck tape. Fix the root
problem, don't just cover it up. Otherwise it's a bit like losing your front door key, and deciding Yourll just leave your front door open all the time rather than calling a locksmith to fit you a new lock.
I'd take it back to the dealer and get them to fix it, seems to be a known issue so should be done under warranty.
If you really want to fix it yourself, then probably some rubber strips glued under the seal, between the seal and the metalwork - a cut up bike inner tube or similar - to pack it out, as looking at both of my cars- although I don't get wind noise- the rubber seal is very loose in the metalwork and from reading another members post, that seems to be much along the lines of the seat dealer fix, although they probably use special Seat rubber inner tube
