Believe that is your boost control open your bonnet look straight down on your boost pipe you will see a cable plugs into a little black unit on the boost pipe get a torx that fits it unplug it and unscrew it check the end is clean get a paper towel clean it try it again see if it works if it doesn’t then get a new one they ain’t much from eurocarparts or tps
