jimcupraturbo Active Member Nov 23, 2013 54 0 Oct 21, 2014 #1 When driving along at 60 to 70 mph I've noticed I can hear like a hissing sound coming from the dump valve sounds like a leak can anyone help
nd-photo.nl Active Member Mar 6, 2012 4,784 741 The Netherlands youtube.com Oct 21, 2014 #2 Which brand+model dump valve? Last edited: Oct 21, 2014
Sean886 Active Member May 15, 2014 312 0 Oct 22, 2014 #4 To say it's coming directly from the dump valve is probably not the right approach. Unless you have super ears! Cover all the joints in fairy liquid. Get it up to the speed it makes noise. Pull over and look for bubbles.
ibizacupra Jack-RIP my little Friend Jul 25, 2001 31,333 18 glos.uk Oct 22, 2014 #5 smoke leak test it
Spirit Furtive Active Member Nov 20, 2010 330 0 Oxfordshire Oct 22, 2014 #6 Do you have an open cone on it?
Spirit Furtive Active Member Nov 20, 2010 330 0 Oxfordshire Oct 22, 2014 #8 Sounds like it could be that rather than a leak. I'm willing to bet that if you put the airbox back on it will go away.
nd-photo.nl Active Member Mar 6, 2012 4,784 741 The Netherlands youtube.com Oct 22, 2014 #9 Induction sound? When did you mount the open cone? When did you start noticing this hissing sound?
Mike20vT Boost it or lose it!! Mar 16, 2014 110 0 South Wales Oct 22, 2014 #10 After I put an open cone on my LC I noticed a hissing when pressing the throttle but thought that was it the induction kit sucking in air Last edited: Oct 22, 2014
nd-photo.nl Active Member Mar 6, 2012 4,784 741 The Netherlands youtube.com Oct 22, 2014 #11 Same here
