I had an interesting find yesterday when mapping the badgerwagen.... on what I thought to be as bought 870cc injectors.. (turn out to be 780cc injectors... fecking suppliers!)
anyhows.. starting at max throttle positions first to see if a problem would show itself, we got as far as 1.3bar boost before running out of injector duty cycle. Some head scratching done at that point..
Checked fuel pressure under power run again and under boost rail pressure was 5.5bar so all there ok and sustained. Not pump then.
swapped injectors for some known 620 siemens ones, and ran again... lean... adjusted them up by the difference in delivery size, re-ran and all was as before, but ran out of fueling from these early up the rpm.. 5500rpm out of puff.
break out the fluke meter which had injector millisecond and duty cycle.. which confirmed indeed that injector duty cycle was going 95% as reported by my standalone DTA.
I am sure I have seen >12ms injector milliseconds on me7 vag-com logging, which at my new rpms of 8800rpm is max'd duty cycle.
Duty cycle is a function of rpm and millisecond opening, so not technically variable... fully open (saturated). Fully open is open.
How is Me7 or vag-com reporting these duty cycles and reported millisecond durations... as from logs I have done before on mine before DTA, my injectors were saturated.
from an on-line site we found yesterday, injectors I will be needing will sit between 1200-1400cc size to run at a max of 85% duty cycle.
2 x 4 injectors it is then.
SEM going to be modified for additional fuel rail etc...
something is mis-reporting injector opengins in me7 tho.
physical fluke meter confirmed saturation so its a real phenomena..
Anyone got suggestions?
