The MFD3 will, but not the standard headunit
Is there no end to what the MFD3 can do.
Would be nice if it made you a cuppa before you go to work
DVD Films too
Apparently No.. But i haven't actually tried driving with the DVD playing yet.
If it doesnt, then i wouldnt be surprised if you can buy a cable that allows it to play. Normally linked up via the handbrake.. i.e. handbrake on, DVD will play if off DVD wont play!
It's a bit more sophisticated than that it read the vehicle speed through the Can Bus -
You need something like this to enable it http://www.kufatec.de/shop/product_info.php/info/p529_TV-in-Motion----Plug---Play----VW-MFD2-RNS2-RNS-510-RNS-810.html
The MDI Media In iPod control is a good optional feature too
Have you tried an iPhone 3g in it, just wondered if it charges and works ok... thinking of getting the MDI especially now I can stream all the music from my home pc to the iPhone
Tried a Pre - 3G one and worked and charged fine, I recall the charging pin changed position on the connector on the 3G ones though, so although it would work I'm not sure about the charging
