Dynamic rear turn lights
Stefan147
193
140
Athens Greece
Done those. Not what you may have in mind seeing an Audi for example or a set for mirror brinkers. It just splits the blinker line in two. That's probably all we can do with the existing hw.
Jaco2k
AWD FTW
Mar 11, 2018
1,037
635
Tampere, Finland
www.youtube.com
Sorry if this has been raised before but could not find a thread dealing with this. Has anyone experience of fitting these? Would like to see them in action if you have.
https://www.carsystems.eu/seat-leon...-kit-rear-led-dynamic-turn-lights,id3039.html
Don't waste your time with that - it can be done with coding and, as already mentioned... it is not the Audi sweeping thing: It just alternates between outside light and inside like (as in the one in the trunk of the car)
Diamond123
30
Your in luck. I bought the same mod from carsystems too.
To tell you the truth, it’s absolute kek the result.
You do not... I repeat do not get the same effect as an Audi Dyanmic indicator. Coding, mod, doesn’t matter you won’t get it.
This mod just separates the two LED units (split from the boot) so it looks like a semi dynamic turn signal.
I did however see a video floating about of some car mod in Germany achieve the true Audi dynamic effect but they modded the entire unit, stripped out the indicator and replaced it with one that you could code each individual LED light.
Cupra300Jay
51
38
this might sound silly but could you not put 290 rear lights onto a 300 then would it have the dynamic lighting
part numbers are similar apart from the end letter
Diamond123
30
Found the dynamic indicators, they ship worldwide now apprently which they didn’t before. Cost you an arm and a leg tho, about £1,100 lol.
Seems like they give you brand new tail lights hence the large cost. Cool if you had the money to burn just on a indicator :)
