Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Sorry, I don’t know the answer to your tailgate issue but It might be worth doing a wider internet search and also include other Seat or VAG models with electric tailgates to see if possible causes for faulty opening might also be relevant to your car.
Here are links to a couple of the search results from doing a Google search on ‘Seat electric tailgate malfunction’. Searching on VAG, VW or Audi instead of Seat is likely to produce other search results too that might be the same as the issue you have.
Hi there, I'm having an intermittent problem with opening the tailgate on my 2018 Excellence ... it will unlock and start to open, then stop and sound the 3 error beeps. There's no apparent consistency on where it fails ... sometimes it does it as soon as the tailgate starts to move, other...
Hi guys, Having an issue with my Tarraco tailgate. When I engage open via any means (key fob, internal button or tailgate button) the tailgate only opens an inch or so and then gives a number of quick sequential beeps, then doesn't move. It won't shut when pressing the button inside the...
I ignored the instruction to wave your foot back and forth because it hardly ever worked, but if I swipe my foot from side to side it works about 90% of the time.
This is what I do too, and in the left side of the bumper around the tailpipe - not in the middle.
Haven't quite gotten the technique down to it being reliable yet
Has anyone located the actual sensors? I've been trying to find them to go at this more systematically.
Mine works fine, obviously u need your key on you and stand close to the bumper. But works probably 95% of the time.
I have more issues shutting it. Had about four occasions where it won't shut, and I have to close it manually, but keep opening it again. Can get quite embarrassing in my Morrisons car park closing it, the car then unclicks it and it pops up again, rinse and repeat until swearing. My only guess is that it thinks the key is in the car and does it to prevent you locking yourself out.
Anyone else had that?
I think I've taken your missing 5% as that is all mine will work. I've given up using it as well as KESSY most of the time as I have to have the key in my hand anyway for that to work so keyless is pointless.
If it like the Ateca it's a kick in the middle and step back or sideways. It needs to know you have moved out of the way. Kick your foot underneath without breaking the Kessy proximity means it won't open.
