electric windows
hemelbear
the windows on the passenger side both front and back will go down from the button on the door but not up i need to do it from the master buttons on the drivers door anyone any ideas what is wrong
the drivers side front and back are fine cheers in advance
healy6660
Right Old Giffer
Mar 30, 2007
77
Cumbria
sounds like a broken wire in the bundle that runs from the door to the bodywork (usually inside the crinkly rubber tube inside the door shut area) or possibly the up connection in the switch
take the door card off and check the connector on the switch hasn't come off
then you need to start checking the wiring and the fuses (I know you probably started there anyway) it does seem unusual that front and back have gone at the same time though
If you don't have a multimeter, or the confidence to use one it looks like you will need to get friendly with an auto electrician
