Electrical issues now with vcds results
nath86
199
Newquay, cornwall
Follow the issues in my previous thread http://www.seatcupra.net/forums/showthread.php?t=433196
I found a work mate with vcds and this is what it cam up with
Thursday,22,September,2016,16:05:32:32264
VCDS Version: Release 11.11.3
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 AE HW: 3C0 937 049 AE
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: E38E0F2F00041000431D00000000000000007F075C4000
Work Shop Code: WSC 06441 785 00200
Additional Info: 1P0955119B Wischer 160107 022 0601 1P0955559 REGENLICHTSENSORH04 0090
VCID: 6CDDDA694F90D69
7 Faults Found:
01333 - Door Control Module; Rear Left (J388)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
OFF
OFF
OFF
OFF
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.25 V
OFF
OFF
OFF
OFF
OFF
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 102
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 8.00 V
OFF
OFF
OFF
OFF
OFF
00154 - Windshield Wiper Motor; Passenger Side (V217)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 103
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 10.60 V
OFF
ON
OFF
OFF
OFF
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 103
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 10.50 V
OFF
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 102
Mileage: 0 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.30 V
OFF
OFF
OFF
OFF
OFF
01598 - Drive Battery Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 254
Reset counter: 114
Mileage: 101710 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.35 V
ON
ON
OFF
OFF
OFF
These code i believe come up when the battery is disconected this was cleared but cam back on shortly after
Also found this code p0688
https://www.google.co.uk/url?q=http...ggbMAA&usg=AFQjCNHI5SCnn4g3sIT9x2TkmWvSj1zkew
But cars not shown any of the symptoms shown and starts fine
Could my issues be down to a bad ground/battery earth lead or battery relay
Any help with this is appreciated
Edit:- just found that when my demister light flashes ( google search suggest low voltage) if i switch the engine off and then restart the car it works again
SWANSWAY CUPRA Dealership
