Electronic Handbrake Fault?
iScoTT29
191
52
I was driving around on Friday night, had done about 50 miles and pulled over to stop for 15 minutes. After having pulled in I turned the car off and then switched the ignition back on. After about 5 minutes 'Electronic Handbrake Fault' appeared on the dash and it also said 'auto hold unavailable'. I turned the ignition off and turned the car back on and the warning had gone and it hasn't come back since. The car is due its 3rd year service and first MOT in a few weeks with the warranty expiring soon so this has concerned me as the usual dealership wont look into it during the service unless the error is present on the day. Anyone had anything similar happen or any advice?
Thanks.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
It should of thrown a fault code which will of been logged and will be visible with a scan from and obdII reader. Should point out the issue.
Reactions: iScoTT29
iScoTT29
191
52
That's good to hear. I'll make sure the dealership scan the car during the service. Would be a nightmare if there was an issue just after the warranty expired.
Mar 5, 2025
Thanks.
Hi reviving this thread as this happened to my girlfriend today, similar situation to yourself did the fault persist or did the car have a slight wobble and worked normal after ?
SRGTD
2,682
1,529
@Adamp - you might not get a reply from forum member @iScoTT29 as they’ve not been active on the forum for nearly three years (last logged on on 25 June 2022).
