markpile
Wolves till i die!!!!
Mar 15, 2014
430
Wolverhampton
So just dropped the wife at work driving under speed limit no boost car was warmed up as not long back from mot and on it cam so drive home steady did a check with torque and said secondary air injection incorrect flow detected, what shall I do what is broke please no idiot answers Only sensible honest help. Thanks
Sent from my C6603 using Tapatalk
I would clear the codes, give it a run and see if it comes up again. It might have just been a temporary faulty reading?
Sent from my GT-I9100 using Tapatalk
Apart from the exhaust blow thread, the chip or chips in the windscreen or are those threads my imagination playing tricks on me?
I'm sure if you used the search bar you'd find most answers to your threads / questions :)
lol there not problems, car was mot'd today and exhaust is not blowing and achip in the windscreen lol that was me asking if anyone used anyone other than autoglass,
Anyways I'd buy a static code reader. (I've got a VGate VS450)
Scan the car for faults (I'm not familiar with Torque App)
Either Google or search fault code numbers on here and you'll probably find most answers to your questions.
I don't mean to sound like a **** I'm just wondering if the search function's working properly as I'm sure most topics have been covered before
Apologies
Anyway search eBay for SAI bypass it'll provide a kit you can bypass the SAI which leaves less likely to go wrong :)
Good luck hope it's an easy fix :)
Had a nose under the bonnet and the corrugated pipe that goes to air box had come off looks like the clip is broke, cleared fault went for a good drive and no light lol
