So looking below at your car data, it would show that index is "0A" therefore you need the following part number:
6Q0-909-605-A 0A
I managed to find one of these boxed for £35 inc p+p on Ebay.de so maybe try there.
You have a lot of codes there. Unfortunetely you have a 65535 error code. This is because of this:
http://www.ross-tech.com/vag-com/vw_issues.html
You can fix it by removing the airbag ECU and sending it away to a company that can reset your airbag ECU. The code was caused from your ebay cable and the free software that comes with it. I fell at the same hurdle! For some reason the cable gives the same error code as you would get if you crashed.
You also need to replace both airbag crash sensors, they are located under the front seats so they will have to come out. The carpet also has to come out for this job.
Your low voltage and seatbelt tensioner I am not sure about. I think I got the same codes once I had removed the seat and checked for codes (with the seat still out).
YOU CANNOT CLEAR ANY ERROR CODES WHILE THE 65535 CODE IS ON YOUR ECU. YOU HAVE TO EITHER SEND IT AWAY TO A SPECIALIST (ROUGHLY £40) OR BUY A NEW MODULE FROM THE DEALER (£LOADS)
Let us know if you need any more
help.
VCDS-Lite Version: Release 1.2
Friday, 06 December 2013, 12:26:42.
Control Module Part Number: 1C0 909 605 A
Component and/or Version: 1L AIRBAG VW51 0A 0004 <-- -- THIS LINE GIVES YOU THE INDEX OF "0A"
Software
Coding: 12620
Work
Shop Code: WSC 06441
VCID: 2237698BBDD7
6 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
65535 - Shareware Version. To Decode all DTCs
00-00 - Please Register/Activate
00654 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
29-10 - Short to Ground - Intermittent
01221 - Shareware Version. To Decode all DTCs
28-10 - Please Register/Activate - Intermittent
01222 - Shareware Version. To Decode all DTCs
