Hi All,
I wondered if anyone could help me identity some/any possible cause of a knocking sound I seem to be experiencing from my LC.
Basically, the knocking occurs when the car is not under load, so either when just at a constant speed on a flat/downhill bit of road where the throttle isn't used much, or when out of gear and just coasting to a stop (like the stop/ start in first in a queue, or slipping it into 2nd when approaching a roundabout for example.)
The knocking sound sounds like its coming from the engine area in general, more on the drivers side than the passenger side, but it's not particularly directional, it just sounds like the 'front' as a whole. When breaking with the clutch down, if the knocking occurs I can sometimes slightly feel it through the peddles but not like a strong judder or anything, just like the residual vibrations of something physically knocking in front of the peddles/in the engine bay.
The knocking 'frequency' if that's the right term! seems related to the speed I'm travelling, so in 1st in a queue the knocking has say 0.5-1.0 second inbetween knocks, but at say 30 coming up behind something and letting off the throttle it the frequency would be perhaps 3-4 times a second.
This is all on straight roads and when pressing the throttle the knocking goes away.
I did some searching on here but couldn't track anything down which seemed to be similar enough to hijack a thread!
I will take it to the garage as soon as I can, I just wondered if anyone had seen (heard!) this type of problem before and could suggest anything I could either look at myself, or suggest to the garage to narrow down their search.
Any ideas?
Any ideas?
