Olly20VT
1,233
Stroud Glos ,England
i know my engine code and i know it should be on my V5 but the DVLA has that at the mow but my insuranse company wants to know my engine code, so were is it on the car?
Iv found my chassey number but not engine number. iv done a search but couldent find anything.
acidstrato said:
AYP?
its on a little piece of metal sticking out of the head
thats the engine code
what he is looking for is the engine number which is located on the front of the block just below the head gasket
are you with adrian flux by any chance? if you are and your filling out the modified vehicle report form just leave it blank, i did and i returned it and adrian flux sent me a letter confirming everything was ok on the form so i wouldnt worry!
ha ha how did you know :D
i am real only updating it so they should have it, but i like to do EVERYTHING by the book when it comes to insurance as the last thing i want is to give them a loophole.
how old are you fella and how much are they charging you? im 22, 3 years no claims, 1 sp30 back in 2001 and im paying £920 fully comp with all mods declared
i had a look and couldent see it?
Davidol = i pay 1200 all mods diclared i was 24 with 3 yncb when i took it out.
and iv been quoted 1400 with a ko3s fitted.
Should be lower now in 25 with 4 yncb when i renew it in april
i just did my adrian flux sheet last week i couldn't find mine either so i rang up and they said that as long as i had the chassis number it would be fine
lift the engine cover up or off on the drivers side
look for the plastic timing belt cover (side of engine)
small bar code label on the top along the bottom you should see numero de mouteur AYP 123456 or similar
NB - dont wipe it if its dirty you will take the numbers off :p
