Engine Oil Light Flashing
lluna_polanco
32
Hello Guys,
As the title states my engine oil have started flashing, the oil level is high and there seems to be oil going to the top of the engine.
A little background, about to weeks ago the water intake of the engine broke and lost all the water, where I was at that moment I was unable to stop and let the car cool off, so the engine got really really hot, but it did not overheated according to the engine temp prob, however it was hot.
The car went to the shop to have that fixed and after 10 miles or so the engine oil light started flashing just as it shows in the crappy video that I took a minute ago so I can upload it here.
Any pointer would be greatly appreciated.
Legojon
I only wanted a remap
5,284
2,714
I thought the oil light was oil pressure not oil level (although from what I gather some Seats have both). Blocked oil pickup?
Reactions: lluna_polanco
R3k1355
1,787
251
Yorkshire
Yea thats the oil pressure light, if that comes on then the engine is already ******.
Hopefully it's just an issue with the sensor or wiring.
lluna_polanco
32
I hope is blocked oil pickup, im taking the oil pan out tomorrow and check everything, regardless the engine is due for an oil change.
I believe the engine is alright, there is no sound whatsoever and no weird shake and there is oil in the engine head (Can actually be seen splattering around.) But tomorrow will be the determining factor if there's metal shavings in the oil pan or not.
Thats something else that I could check, oil sensor and wiring
Something that I found weird is that after idling a bit there was some oil in the floor which would lead me to believe that either the RTV or the pan gasket failed. as the only place I was able to see oil was on the oil pan itself.
lluna_polanco
32
So, pulled the oil pan out today.
Oil had no metal shavings :coolthumb
Oil filter was loose and thats were the oil was spilling:wtf:
The Oil Pickup was clean.
Needs to go to the electrician on Monday to have the oil pressure sensor swapped, if changing this makes no difference, then the car is going to the shop again, because then it might be the oil pump lifting pressure but not enough.
Best thing is that the engine is healthy (At least block head and pistons), so I'm good
lluna_polanco
32
Ok, finnally found the culprit, oil preasure sensor was slightly loose and with no gasket or or ring.. Found it because of a massive oil puddle when parked the car
Sent from my SM-G955F using Tapatalk
lluna_polanco
32
Soooo, gasket maker didn't work, so tomorrow im off to buy a oil preasure sensor from my local VAG parts dealer
RUM4MO
7,824
1,000
South Scotland
I think that oil pressure switch leaking and so failing is a very common issue with VW Group cars, now that you have mentioned it!
lluna_polanco
32
Indeed it scared the **** out of me.
Well, ive swapped the sensor today and all is good now, the take from this is, is the oil pressure light ks going off, check if you have oil pressure in the head if so, then swap you oil presure sensor and be done, if you do no have oil pressure in the head of the engine take it to a shop and dont drive
lluna_polanco
32
The point was to have them swap the engine.... At least in my country is cheaper to fix the head/block or swap them than getting a new car
