Vendelay
35
Deep Down the Rabbit Hole
hello everyone !
i don't know if it's true but i figured this is the best place to ask... :)
can i see engine parameters such as speed or RPM in the climate control display ??
i heard that i can browse between codes and see all kind of interesting stuff.
is it possible and if so, how can i do it ?
Thanks !
I think on the Leons you can, but not on the Ibiza.
You CAN see some climate control related stuff, like individual temp sensor readings etc.
IIRC you press the right hand three buttons together. Then a spanner comes on and you use one of the dials to change which reading you're looking at. I think it's the temp dial. I haven't done this in ages ;)
yes this does work if you have climate control hold down the 3 air directional buttons then press the air recycle button iirc. Then turn one of the knob to flick through the codes
