I don't get this.
Isn't the clutch only used during gear changes. How can accelerating in a given gear at low revs damaging the clutch. Unless you're slipping the clutch in order to accelerate???
What do you think connects yours engine and gearbox
Low revs in TC car = High torque values
High Gear + High Torque value = Long time riding that high torque curve.
Use 300lbft for 20 secs accelerating in 6th
Or
Use 300lbft for 10 secs accelerating in 5th/4th
What do you think will cause more general wear and tear
caec....Surprising the mechanic or garage did not know what clutch slip was
Make sure you take it to a different garage when you get it sortedClutch slip will happen with any engine, just wear and tear at the end of the day. Clutch slip obviously more common on higher performance TD's such as the 130/150/170 vag units especially if remapped.
Could of course be oil dripping onto friction plate and causing it to slip rather than wear on the friction plate! Best getting it checked as too much slipping can damage the flywheel in turn.
