I've noticed this past week that my car stutters slightly when running from cold (would normally be OK after a minute) - not only that but it sometimes takes longer to turn over.
Less than 6 months ago I had the same symptoms and found the coil pack to be the culprit, when I took it out it looked proper corroded/rusted. Replacing for a new one fixed it immediately. Great...
A few months after this I had more issues with the same coil pack - it had developed a crack and caused an arc burning out part of my wiring loom (all happened whilst in the care of a garage) - so that was replaced along with part of the loom and all was good again.
So here we are again, was driving to work and instantly knew something wasn't quite right. The engine stutters were becoming allot more obvious and I got 3/4 of the way to work and the engine started shaking like crazy and had barely any power, the engine light came on and I just about limped it to work.
I checked all four coil packs, and once again, the SAME cylinder from the previous two incidents was to blame.
The coilpack:
Chamber: (looks like it corroded all the way down???)
I am mainly concerned with the condition of the ignition chamber, it should be clean right? There's definitely something happening within cylinder 1 that keeps causing the coil pack to corrode/rust. I've never had a problem with the other 3.
I'm not sure if this means anything, but removing this particular coil pack was agony! Each time it started to move it was like it was getting sucked back in? The others were a breeze.
Thanks for any help.
The coilpack:
