Hi all,
I jumped in my car this morning to go to work only to find the EPC and EML lights illuminated on the dash.
My car is still under warranty from the dealers (12 months warranty for used cars from Seat approved dealers) so I called the dealers who put me in touch with Seat roadside assistance who came tonight after work to diagnose the cause and try to put it right.
It turns out the turbo actuator had stuck and caused the car to go into limp mode. After clearing the codes and giving the actuator a few good taps with a hammer the car is running properly again.
The AA mechanic seat sent said this is the very first fault of this kind he's seat on the 1.2 tsi engine and that the problem is sadly likely to re-occur.
I'd read a bit about what was likely to be the issue with this code before he arrived and I hadn't come across this particular fault either so thought I would post it to try and give anybody with the same symptoms a heads up.
I'll be making a trip to the dealers this weekend to try and get them to replace the unit before it ruins my commute again!
