toonfiend
Hail to the Plug!!!!
Jun 27, 2008
159
My Mk2 (16V ABF) was doing this with ever increasing regularity, pull up at lights or junctions and it would take it upon itself to sit and rev at anything up to 3K, go down the road a bit and was OK again. Very annoying. After cleaning out my ICV, Throttle body and associated bits and bobs for the umpteenth time, and it still did it, I decided to look for other possible causes. It didnt take me long to find something interesting......
There are 2 electrical connectors on the throttle body one on the lower front and a smaller one on the upper rear.....
Now, I dont know what they do but im sure they must be responsible for sending some sort of electrical signal with regard how far open your throttle is so the ECU can work out air/fuel mix, if anyone knows feel free to jump in!!
The wiring for these connectors runs along the back of the top of the engine block and is fastened directly to the cam cover by 2 clips. They are covered by a thin plastic cover. When I undid them and took a look I discovered something truly horrific!!
The heat from the engine block had more or less melted the plastic cover away on the smaller connector and the wiring as you can see is fried, KFC`s got nothing on these babys. The wires were so crispy one of them actually just snapped off while I was removing it.
I cut out the crispy deep fried length and spliced in some new bits, wrapped the whole lot in heat reflective sheet ( that`ll be tin foil then...:lol:), and ran the wiring through an old bit of aluminium duct tube I had keeping it away from the engine block.
Since I did that nearly 2 weeks ago Ive not had one incident of random over revving at idle.Is it cured? Hey its a Mk2! anything can happen in the next half hour!!!
Could be worth checking if yours is doing this, Cheers TF:D
never a truer word spoken :lol:
it's not so bad where it runs but the manifold get so damn hot it just fries the loom, in fact most of em i have seen have had a repair at the switch end already
The wiring for these connectors runs along the back of the top of the long engine block and is fastened directly to the cam cover by 2 clips. They are covered by a thin plastic cover. When I undid them and took a look I discovered something truly horrific!!
What could I possibly first do when I have melted the plastic cover from the heat from the engine block
you can get the connectors seperately if needed but trace the wires back to the cleanest part you can is best bet
Yep, just as flapper says, free as much of the wiring as you can to see how much is ruined, then cut it out and splice in some new bits. About 6 inches of mine was wrecked. You need to get rid of all the wiring that is stiff.
i have what seems to be the same problem with my 2.0 8v, engine code AGG has anyone else had this? do u reckon it might be the same thing :)
cheers guys
