Error 01314 ABS related fault/engine management light
Matthew Dada
Hello there I am new to the forum and would like some help please. I have a 2011 seat Leon fr+ and I get error 01314 when I plug it into a obd reader. The abs lights flashes when the error is generated. Anyone come across this problem before and knows the solution?
Rusty2k
718
142
There was an ABS recall, but on earlier cars. Up to 2009 or 2010 I think from memory. Besides, the issue with that particular ABS fault was the unit being unable to detect a certain fault and therefore failing to produce an error when it should have been.
See if you can get the car scanned with VCDS or similar to get some more info from the ECU.
