tamer_sarji
7
When i put my gear in Sport mode
The Gear didn't get in 4th (s4) it was stuck in 3rd and a check engine light turned on for few seconds then i get this error
I did reset the fault and tried again then it was the 5th gear that didnt get in and the fault turned up again
I didn't find anything useful in google can someone help me?
Sent from my SM-G955F using Tapatalk
Reactions: Yousef
Think it's pretty much what it says, the clutch is worn. I realise it's a DSG. From what I've read, DSG is basically two manual units in one housing.
Looks that way. Has the DSG been serviced / fluid changed at the right intervals?
Yes it has
Now im reading that maybe a software update will fix the problem it is a thread from 2014
It's worth a try as it's a cheaper option. If it's the one I'm thinking of it does something like increase the allowed tolerance.
