Exeo Coolant Bleed TDI
Dec 15, 2022
Hey Guys,
I have a 2011 Seat Exeo 2.0 TDI 143bhp, I got the thermostat changed 2 days ago as it was stuck open, the car reaches temperature now perfectly but I am get cold air coming from the heater, but warms up when driving. It doesn't warm up to how hot it should be like when it's on Hi it'll blow like 22 degrees heat.
First I thought it was air still in the system, so I have bled the car 3 times since I've gotten the car back. No bubbles, all is good. My bleeding procedure was, Car on --> Heat Set to Max/Hi --> Fans on Max --> Coolant Reservoir Cap off. And I bled for 30 mins to an hour and no hot air coming from the heater when idle. But the car reaches and keeps temperature fine.
Am I missing something?
Thanks guys
Sep 2, 2024
Having the same problem changed power steering pump removed coolant pipes drained coolant refilled left cap off for half hour while idling no bubbles put cap bk on heater blows hot and cold air but no pressure in coolant bottle what am i doing wrong any help would be appropriated thank you.
