Exeo Front Bumper Removal
BloodnutsTDI
16
Hi All, how easy is it to remove the front bumper? No headlight washers or parking sensors are fitted, I want to fit an LCR splitter and reckon it would be easier to do off the car.
Thanks in advance, Ian
Tonyuk74
185
Barnsley
It's not hard at all. Pull back the inner wheel arch covers. There's a couple of torque screws under there each side. There's 2 10mm head nuts each side under head lights access from wheel arch. Front grill has 2 plastic rivets on top. Work them out with screw driver or panal removal folk. Grill is tricky but basically just pulls up and out to front. I think there's a few torque screws under there. Drop under tray off. Once you got all screws pull out the bumper from the bracket that hold bumper to wing,pull out and forward at same time. I think that's it. There could be 2 screws that are tricky to see between the head light and the grill. If in doubt just gently pull bumper and u should see where it's been held. Hope this helps
Tonyuk74
185
Barnsley
Little trick place tissue paper over socket and push the nut in to the socket the tissue will make it a nice snug fit so the nut doesn't fall out
