Formentor John
37
15
Hi all
I have just took delivery of a new facelift V2 1.5 eTSI, coming from a pre facelift 2022 V2. Whilst I can live with out the leather, I was shocked to see how much lower quality the car carpets are! also the parcel shelf and boot lining materials. Even the owners book wallet is made from the cheapest eco paper.
Drive wise it feels a bit smoother to pull away although after a short drive it is clear the wheel alignment is out, and despite being new the sat nav is way out of date. Annoying as both look like a dealer visit.
Has any one used the cabin vent/fan feature on the Cupra app? I have pressed the on button, however my phone freezes when pressed and nothing happens in the car.
Thanks in advance for any advice on the above.
Reactions: Steve-Formentor
How can you tell after a short drive the wheel alignment is out?
Check the "navigation database" field in Settings -> System information on your infotainment; maps version should be second half of this year - I don't remember exactly.
The App works quite well most of the time - I used almost daily for battery charging control (PHEV) and for climate preconditioning.
Try to clear cache/data of you App, update if necessary... last versions seemed to be quite stable. Some older versions I used were a nightmare on several occasions.
Hi all
Regarding wheel alignment, are you turning lane assist off? If left on, it can cause unpredictable, uncommanded steering inputs that mimic bad wheel alignment. I turn it off every trip now.
