Failed MOT
RickC
BUILT NOT BOUGHT
Dec 23, 2004
1,621
Lincoln
all went through fine just failed on the 2 CV boots that have been stretched and show signs of splittind when on full lock, i cant see it something i have done,
well its in on monday for repair and retest, doh
CupraSteve
790
have they abloshied the free retest within a certain period then?
surely they cant get away with that as they wont have to do a full test again, only test the repaired part
When mine failed due to me stretching the life of the tyres too far and a broken exhaust bracket they retested mine for free.
rst_cupra_r
jamie from essex
Jul 23, 2005
470
Braintree, Essex
as they all say just a cheap fix its normally due to the car bein lowered an on bigger wheels just makes thm strain abit more thn they should same as track rod ends go (the rubber perishes) quite commonly on lowered bigger wheel'd cars
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
with the new regulations they have to do a full retest if the vehicle leaves teh premises
the main problem is that they now have to login to do the actual test and even if they only have a few small items to check the machine as such is tied up for a minimum period so hence they charge for that time period
good news is that because of all the hassle involved with the mot test in general now you see a lot more - minor faults - let through than previously
as per usual the system designed to tighten up on procedures actually causes so much hassles it in turn has a detriemnt effect on the test it was designed for :lol:
flashbsd
i get my whole MOT done for free (favours in the trade) and he would probably fix it before he tested it anyways ;)
