Hi all, is there a guide out there for replacing the fans? before everyone jumps on straight away with the slow speed fault i need to sort one that doesnt work. My small fan doesnt work at all.
Big fan cuts in at slow speed when the car reaches 96ish untill 89-90 degrees, no small fan.
Checked with the 3 pin plug, again big fan runs on slow speed and fast speed when tested.
AC on big fan runs at slow speed.
Small fan does nothing at any time so i need to remove it to check it and replace. Im not sure if i need to do the resistor mod as the big fan runs fast and slow when tested but main priority is to get them both working to start with.
