EdButler
713
Sheffield
Hi people,
I was just wondering if there is such thing as a faster syncing cable on VAG COM. I notice that on version 3.1 when i test my cable it says "fast sync compatible : NO"
I have tried this with third party cables based on both opto couplers and an more modern (version 4.x interface) with no avail.
Could anyone give me any hints as to how i would get a faster sync rate? Its currently polling at around 2.7 polls/sec on only 1 measuring block...
Many Thanks
Ed
http://www.ross-tech.com/vag-com/tour/m-blocks.html#turbo
In Engine controllers using KWP-2000, there is a [Turbo] button in Measuring Blocks screen. Pressing this button can significantly speed up sampling, for example over 30 samples per second when logging a single group in our Touareg. Once you have pressed [Turbo] you will remain in this High-Speed mode until you exit the Measuring Blocks screen. This function is only available when using a HEX Interface.
Dont know if this is what your after?? But it looks like you need one of the profesional kits to do it :(
Yep cheers mate, thats the information i was after! Looks as though ill just have to squeeze as many iterations as i can out of what ive got!
Cheers, Ed
