Fault Code 17695.P1287
G3K
3 points and counting...
Aug 14, 2010
451
Hatfield, Herts
Driving to work this morning my LCR seemed a bit lumpy on accerleration for a min. Scanned for fault codes when I parked and this code came up: 17695.P1287
I cleaned and oiled my DV this weekend, could the two be related?
Has anyone got any ideas?
G3K
Aug 14, 2010
451
Hatfield, Herts
Ok, checked the DV and the pipes for boost leaks and no problems there. Unplugged the maf sensor and took it for a drive and the problems was still there.
Has anyone got any other ideas before I take it to the dealers??
I've had fault free driving for 12 months and now problems for the last month or two
G3K
Aug 14, 2010
451
Hatfield, Herts
What did you "oil" the DV with? Did you test it to see if it sticks open afterwards?
Hi mate,
I used the red grease, bought a service it for the DV with the rubbers. Yep the DV is all working as it should.
I managed to find and fix the fault about 30 mins ago.
The car was serviced last week, turns out the plug for the N249 wasn't plugged in...simple as that and a day of stress! I didn't notice it was unplugged till then!
I did a N249 bypass while I was messing about too. Scanned the car for faults afterwards and none found.
Thanks for your help guys, the Cupra R is back to how it should be.
:):D:D:D:D:)
black night01
i have this code p1287 has just poped up when scanned is it my resistors or me forge split r dv can eney 1 help or shell i clean and oil dv and try pluging the 2 valves back in just incase thay have blone for some reason
