damo-p
58
w-s-m
hey guys so i got these faul codes on my car and was wandering what could fix them?
a friend put in on his scanner and i dont know much about fault codes lol
i have got of my arse and found what they mean though so here goes
16524 P0140 O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
16486 P0102 Mass or Volume Air Flow Circ Low Input
17522 P1114 Bank1-Sensor2 Internal Resistant too High
17524 P1116 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
17526 P1118 O2 Sensor Heater Circ.,Bank1-Sensor2 Open
17956 P1548 Boost Pressure Contr.Valve Open
17964 P1556 Charge Pressure Contr. Negative Deviation
17968 P1560 Maximum Engine Speed Exceeded
i found these here http://www.seatcupra.net/forums/showthread.php?t=47135&highlight=seat+fault+codes
it is decatedd if that makes any differance
any help would be much appreciated as i cant afford to put it in a garage right now
Erase them and see which ones come back first, unless you want to spend money on every single fault, which i doubt.
Hi guys thanks for the replys
I have a new maf on order now so will see what that brings or clears should I say
As for there being a boost leak it doesn't feel as pokey but still reads 1.25 bar when boosting on the gauge. Could there still be a problem? If so I guess changing silicon hosing for the bypass and such would be first option could anyone tell me what size or does anyone have some I could give u a coupe of quid for through paypal?
Cheers again
