Fault Code HELP!!
Skinner33
Right management light has come on!!! :cry:
Got the car mapped the other week now the management light has come on. Plugged the code reader in and have 3 codes
17956/p1548 - Boost pressure regulation valve n75 open circuit.
17705/p1297 - pressure drop between turbo and throttle valve check dv.
17545/p1137 - fuel trim bank1 system too rich.
I have a forge 007p fitted with the yellow spring.
Anyone help me out? Thanks
Skinner33
No not been smoke tested I just plugged the code reader in tonight when wife came home with the car
WadGTI
8
yeah sounds like a vac leak. Also if you have vagcom, check the fuel trim values under block 032 :)
