Hi
As in the title i am having a few issues with my 04 LCR. I have to codes below come up
17608 - Boost Pressure Control Valve (N249) Mechanical Malfunction P1200 Intermittent
16395 - Bank 1 Camshaft A (Intake) Retard Setpoint not Reached (Over-Advanced) P0011 Intermittent
I have been searching and reading loads about the 17608 code. Various people talking about it might be a faulty N249 or a faulty N75. Also had an interesting read about someone having idle problems and power loss. It turned out to be a split hose under the intake manifold.
These are the same issues that i have been having for a few weeks now, I have checked all the hoses as best i can and cant seem to find any splits. The only thing i found was the vacuum pipe from the recirc valve was abit loose. I have tightened that and cleared the codes but still no luck
Is it possible that the bailey recirc valve i have is faulty? i had the forge 007p on my previous car but this was on it when i brought it
Not really sure what i need to do with the 16395 code. Ive been on wiki.ross-tech.com and that simply says to check the Camshaft Adjustment Valve 1 (N205), Check Fuel Pump Relay (J17) & Check Mechanical Timing
How do i go about checking those valves etc???
Sorry for the essay but thought i should say all the details i have
Any help would be a great help
