Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
See I borrowed an n75 off an octavia vrs that was in workan still same result...
How do you go about vac testing the actuator?
Was it the same N75 valve tho? There are 3 F, J and H you really shout be matching it to yours for a testcheck the part number on yours to see witch on it is
neither did i mate. It was only the fact that i had followed all the advice on here with no luck i then took it to my dad. Didnt take him long to check it and find the source of the problem. Well at least i hope thats all it is
Yes, if the log is saved then you'll be able to import to Excel and/or copy and paste here.
Regarding the other code in your first post, "16395 - Bank 1 Camshaft A (Intake) Retard Setpoint not Reached (Over-Advanced)" - get your oil pressure checked at a decent garage, and make sure they check what the spec value should be for your car. I got this one back last night after it had gone away of its' own accord around Christmas. My turbo is also failing at the moment, suspected oil starvation so I'm thinking I've got an oil pressure problem, get yours checked and fixed if necessary. Has this code come back again?
