GrooveChampion
24
7
I noticed that when I scan my 2016 Cupra 290 it occassionally gives me the following faults
Stuck in gear 1 - 6, fault codes: P072C00, P072D00, P072E00, P072F00, P073A00, P073B00
Stuck in reverse code P072B00
Valve 3 in partial transmission 1 code P174A00
Valve 3 in partial transmission 2 code P174E00
Engine Speed Inc.Circ. Code P072600
Pressure Contr. Solenoid C code P079700
Cooling oil valve code P179D00
Starter enable from selector lever sensor code P173400
It's almost always this specific list, sometimes it goes away on its own
There are no lights on my dash to indicate something is wrong and the car drives fine
Anyone experienced something like this?
Are you running a scan on ignition, try again with engine running and see if you still have the faults
Reactions: GrooveChampion
Have you ever delete the transmission adaptations? Did you follow the interval for the transmission oil changes?
Transmission adaptations? Sorry I dont follow
I bought the car with 89K kilometers, I have no idea if the transmission oil was changed sadly
