paradisiac
19
Cornwall
So I cleared the fault codes last night and the car failed to start, stalled or hesitated when accelerating. One of the codes was MAF so unplugged that and car runs fine so require a MAF for sure.
These are the codes that come back after being cleared:
Tuesday, 16 May 2017, 07:24:07
VAG-COM Version: Release 409.1-S
Control Module Part Number: 06A 906 032 T
Component and/or Version: 1.8L R4/5VT 0003
Software Coding: 05510
Work Shop Code: WSC 06441
2 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Tuesday, 16 May 2017, 07:25:26
Control Module Part Number: 1C0 907 379
Component and/or Version: ESP 20 CAN V005
Software Coding: 18945
Work Shop Code: WSC 00000
3 Faults Found:
01314 - Engine Control Module
79-00 - Please Check Fault Codes
01423 - Lateral Acceleration Sensor (G200)
57-00 - Electric Circuit Failure
27-10 - Implausible Signal - Intermittent
Tuesday, 16 May 2017, 07:33:46
Control Module Part Number: 1M0 820 043 C
Component and/or Version: 1M-CLIMATRONIC X0604
Software Coding: 00041
1 Fault Found:
00785 - Temp Sensor in Instrument Panel (G56)
30-00 - Open or Short to B+
I'd replace the maf and then clear the codes and test. Unplugging the maf did bring more codes my way as expected.
Sent from my Nexus 6 using Tapatalk
