Past few days the car keeps going ' beep beep beep ' and flashing the indicator lights. Press of the keyfob shuts it up but it will just do it again.
Annoying at 3am![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
Scanned with vagcom, only errors were:
and
Had a look at some blocks:
Does anyone know what 1.0 might correspond to?
Found some advanced logging as well
I've done some searching and seen some mentions to replacing the drive side door mechanism, is this easy, any vagcom coding required?
Looks to be part 1T0959701C ?
Any help, driving me & neighbours insane.
Annoying at 3am
Code:
Address 46: Central Conv. Labels: None
Control Module Part Number: 1K0 959 433 A
Component and/or Version: KSG
Software Coding:
Work Shop Code: WSC 06441 785 00200
Additional Info: 1K0951605C LIN BACKUP HORN H03 1301 NGS n.mounted
Additional Info: 1P0951171 Innenraumueberw.010 4971
VCID: 2E570A8BB90C5AE
1 Fault Found
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
and
Code:
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
Part No: 1T0 959 701 C
Component: Tuer-SG 024 2452
Coding: 0000688
Shop #: WSC 06441 785 00200
VCID: 37792FEF46569B6
1 Fault Found
01706 - Switch for Mirror-Adjust (E43)
008 - Implausible Signal - Intermittent
Code:
Address 46: Central Conv. (1K0 959 433 AK)
20:19:40 Group 018: Sounder (Alarm Trigger)
1.0 1st Alarm Trigger
1.0 2nd Alarm Trigger
1.0 3rd Alarm Trigger
11.0 Alarm Trigger Counter
Code:
Door Closed Driver Door Rotary Switch
Door Closed Passenger Door Rotary Switch
Door Closed Rear Left Door Rotary Switch
Door Closed Rear Right Door Rotary Switch
Closed Rear Lid Main Latch
Closed Rear Lid Pre-Latch
Closed Hood Contact
129 1st Alarm Trigger
5 1st Alarm Source
