feeling life less
gazjones
eml engine management light? could be maf common cause of poor pickup
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
mate do you know how to comunicate with people? your be lucky if you get any help with the info your giving looks like a 5 yr old is typing for you!! (Your not 5 are you?) there doing you a favor not you doin them one!!! so if i was you id start again tell us wat your problem was tell us wat the garage found and changed and why also wats happening now other than "it dont go like stink and i should"
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Mate your not helping us out here... can you take your time and explain the problem?
More detail?
People are more willing to help if they dont have to do a Professor Cluedo to work out what the problem is...
*EDIT* - Beaten to it :(
Mike
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
More detail?
Mike
you gotter be quick mate theres a fine line between winning and loosing!:lol:
off topic!! not that its goin to matter are you running your car 2moz? my water pump failed last nite so i got cam belt and that to change 2day so i can run[:@]
andycupra
status subject to change
whats a 'naked' lambda..?
i presume you had a new maf and lamda fitted.
try an ecu reset, (negative battery terminal off for few mins) then turn ignition on but dont start the car for a few mins to let throttle align. (do this when car is cold).
then see if car is better. - it may have adapted to previously poor parts.
if this doesnt help. take it straight back.
if you are bothered, you could also dissconnect the maf and see if it drives ok. if it does then the new maf is probably poo.
however, the garage really should help.
ope tis elps you fix t problemo n t car is no longer de crapo...
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Yes mate mine will be running, then agin in a few weeks with DP and Race Cat :D
You still gonna come along somehow?
turboboy
Limp Mode Squad ™
Dec 9, 2003
2,007
hants
ive just fitted the cam belt and water pump and started her up all is well so looks like im coming and running!!
cresswell22
Newbie
Aug 14, 2005
205
haverhill
www.putfile.com
i have done the ecu reset and have tryed unpluging the maf still the same as before i am thinking the only thing i can do is go to the stealers but before i do can anyone think of anything else i will try and explain the problem a couple of weeks ago my engine management light came on but there was no limp mode it still boosted up normaly and still was quick but thought i had better take it to a garage so i did the garage phoned me to say it needed a new lamda i said fine picked it up the next day and matey at the garage said it felt abit flat and needed a new maf so got a new one of them he took me for a drive before the new maf and it did feel flat new maf went on he said it felt better but i dont think it made any difference i have no idea what is up with:cry: :cry: :cry:
