chris285
leon mk1 fr tdi
Nov 26, 2004
1,849
lincoln, uk
well after my car failed its mot due to emissions on sat, taken to the garage today and dropped off
lambda sensor checked and was ok before i left, oil sump pipe was nearly closed and full of gunk. be interesting to see if this is the whole cause or that plus the cat, as it was basically blocked as well
fingers crossed its being blocked as this is the easier one really
looks like its the cat, still under warranty til sat so hopefully fixed friday then retest sat and then taxed at the last minute:(
be careful you will very rarely find a faulty cat - more likely a cat damaged by other causes like over fueling etc
if you get given a new one warranty grab it and run :p
