first scan advice please
HOTTIGGER
hi all ive got 2003 lcr when i bought it the central locking was not working and was told it only needed a new battery in the fob, changed the battery nothing happened, plus both left/right door mirrors dont work/move, ive changed the fuse and still nothing, hear is the vagcom results can someone help me make sence of it please. p.s also fault code 17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat), the temp hand does not move while driving, should i change the thermostat first? or the coolant temperature sensor? thanks in advance.
Sunday,24,March,2013,16:13:38:10462
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1M - Seat Leon/Toledo
Scan: 01 02 03 08 15 17 19 22 35 36 37 46 56
VIN: VSSZZZ1MZ3R098975 Mileage: 118100km/73383miles
Address 01: Engine Labels: None
Part No: 1ML 906 032
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 00000
VCID: FEF8A354FADF2BE8D30
VSSZZZ1MZ3R098975 SEZ7Z0C1913351
1 Fault Found:
P1296 - 35-00 -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK60-F.lbl
Part No: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001 001 00001
VCID: 40849DAC10AB1D1861C
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.lbl
Part No: 1M0 820 043 D
Component: 1M-CLIMATRONIC X0605
Coding: 00041
Shop #: WSC 06402
VCID: 234E3220B1FD26001CE
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0006
Coding: 13113
Shop #: WSC 06441
VCID: 22403724AEE72F08178
Address 17: Instruments Labels: 1M0-920-xx2-17.lbl
Part No: 1M0 920 922 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 05424
Shop #: WSC 00000
VCID: 2C5CD91CDC23E978AD4
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
VCID: F0E48D6CB08B4D9851C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 F
Component: A7 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 06402
VCID: 3A70EF44267747C82F8
Subsystem 1 - Part No: 1C0959802B
Component: A7 Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C0959801C
Component: A7 Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: A7 Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: A7 Tõrsteuer.HR KLO 0009
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1M0 035 186 F
Component: Radio 0001
Coding: 00403
Shop #: WSC 06402
VCID: 2B5EDA00D92DEE40A4E
End ---------------------------------------------------------------------
HOTTIGGER
Any one please.
my central locking is not working I've done a scan but it makes no sence. Thanks. :cry:
towcester vag
1,775
duston northants
you probably need to code the remote part of the key to the cdl
the heated mirrors are shot z4-z5
and its possibly got a dodgy thermostat does the car run at 90 on the temp guage?
